Home > Maintenance & Mods (L322) > 2007TDV8 gallery pressure sensor
Joejag
England 2007 Range Rover Vogue TDV8 Stornoway Grey
Good morning all
My RR is on its bump stops, drier refilled and new pressure sensor fitted to the valve block at rear of compressor after the well was in 20mm of water! My icarsoft tool tells me the air pressure sensor is reading 0.7v and gallery pressure is 0.29MPa. Is there another sensor on the reservoir under the drivers side? is this only available with a new reservoir? I have done the battery disconnect, steering left and right etc. Everything else seems OK and reluctant to replace the AMK compressor as it is certainly pushing out air although it only runs for 15 seconds before the suspension fault stops it. Fault codes for current air supply comes up and when cleared compressor runs again. Gallery pressure remains at 0.29MPa which is obviously too low. All doors and everything else looks OK. Any ideas folks?
Post #519082 20th Jun 2019 10:28am
