![]() | Home > Maintenance & Mods (L322) > Please help - horrific noise :-( |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1395 ![]() ![]() |
Are your ltft plus 22?
I can't visualise which that one is tbh.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
hi dingg - sorry to go over old ground but are you saying before you cleaned and tidied your pcv it sounded exactly the same as mine? Current stable:
Yes.
Sorry about the grammar but I've had a few and posting on phone |
Ok just popped out now to do as you said made 0 difference |
With trims that positive you are most likely pulling in a vast amount of unmetered air somewhere.thatcould explain the noise too.
that's my next play its booked in on Friday ... Current stable:
Hope you get to the bottom of it |
Ok thought I’d better update nobody likes a post which is not finished |
Just to confirm after changing the alt and the pcv (greats fun job the alt) the noise is gone and my ltft at down to 10 and 5 and I thinking that due to the leaking brake booster hose but accidentally got the wrong side through so hopefully can have it good as gold then.
