![]() | Home > Maintenance & Mods (L322) > Service reset iid. |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888
Help please.
| Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102
Please perform the appropriate maintenance prior to resetting. This procedure requires the
Sorted...
Because I got it wrong last time I made myself this little note...
| Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200
Thanks for that Mike. I am being a bit thick as I tried the Service button on mine but only have the oil level check show using right side buttons. Are to referring to a work shop manual by chance? Checked you tube where some other LR models can reset by lifting the bonnet and depressing the accelerator etc. will clear the service req'd light. Thought something similar might apply to my 2012 4.4 tdv8 ?
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Dave
No Dave,
Many thanks Mike and DrRob
| John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447
Just posting to let you guys know i have an autel obd tool, and this offers the option to perform a service reset too.
Although not any 100 % proof of success, the ICarsoft LR11 Diagnostic tool may well have cleared the oil change setting on my V8 td 2012 range rover. It listed auto and manual alternatives. Choosing the manual option it advised a procedure of opening drivers door, bonnet and holding the foot brake for ten seconds together with on and off ignition settings. This seemed very similar to other routines for Land Rovers on you tube. Time will tell but the right oil and filter was changed on the 12 month basis.
| All times are GMT |
