Home > Technical (L322) > 4.2 supercharged coolant hoses p/n under the supercharger
Diesel des
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
Guys hi I'm new here and have a question. I'm replacing the blower on my car with a rebuilt and modified unit from powerhouse and want to swap common failure parts while I'm there. I read the coolant hoses under the blower are a pain to fix, so ideally done now I am doing the blower. Does anybody have the part numbers for these and know of a good place to get them if they are cheeper than the dealership? Any other good things to do while I'm in there?
Cheers des
Post #519768 26th Jun 2019 4:50pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Mine has just had the hose replaced and the hose alone was £262.82. The labour was significant and looking at the pile of parts on the workshop floor, I'm not surprised.
Sorry, no part number for the hose, but it goes from the thermostat housing, under the s/c and disappears towards the back of the engine. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #519775 26th Jun 2019 5:46pm
Diesel des
V8noise, thanks for the response. Does the hose just connect to two things, or does it have multiple offtakes? You don't happen to have the old one that you could grab a picture off? I want to be sure I order the correct one. Did you get yours from the dealership? Cheers des
Post #519780 26th Jun 2019 7:25pm
V8Noise
All done by my indy Des and I'm out of the country so haven't even seen it yet.
Sorry I can't be any more help. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
Post #519782 26th Jun 2019 7:54pm
Diesel des
That's no problem. I will do some more digging. Anyone know of a resource that has diagrams and part numbers for these machines? I'm used to vw Audi cars and there are some great resource for those, effectively what the dealership uses so you can find exactly what you need.
Post #519788 26th Jun 2019 8:27pm
briangunn
United Kingdom 2010 Range Rover Vogue SE TDV8 Buckingham Blue
You can check the wiki as there's three parts catalogs (third party 'clones' of the original) for free.
Or use https://epc.jlr-apps.com/ which you pay for, but is the same as dealers use. I signed up as an independent dealer, it's relatively economical to use..
Post #519802 26th Jun 2019 9:28pm
Diesel des
Can anyone pick the hose required out from this diagram?
Post #519849 27th Jun 2019 1:19pm
Diesel des
Hopefully attached now.
Post #519850 27th Jun 2019 1:20pm
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
if you still need a pic of were hoses go from and too tehn i can take a few snaps from under the blower as mine is currently in pieces?? If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #519854 27th Jun 2019 1:40pm
Diesel des
That would be ideal thanks!
Post #519856 27th Jun 2019 2:12pm
MattHughes86
where my finger is one of the pipes connects to this.
there is a joint here that the other pipe joins to.
they run down the left hand side
and connect into these quick release couplings through the metal 90 degree bends that should be there (they are currently on my back seat)
Hope this helps If In Doubt Give It A Clout
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #519860 27th Jun 2019 3:21pm
Diesel des
Thanks for the help guys. I have ordered this which I think includes the 2 hoses you described. https://rover.ebay.com/rover/0/0/0?mpre=ht...3113089606
Hopefully that covers what I need.
Post #519896 27th Jun 2019 9:25pm
Diesel des
Just to confirm the hoses I linked fitted fine.
Post #521793 15th Jul 2019 3:52pm
friskydog
I am having the same done by powerhouse. Could I ask did you ever have the part numbers for the hoses please? Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #546414 8th Mar 2020 10:45am
