Home > Maintenance & Mods (L322) > Gearbox oil change
Greyskull
England 2009 Range Rover Vogue SE TDV8 Buckingham Blue
Gearbox oil change
Hi all, I’ve only had my Range Rover vogue l322 3.6 tdv8 ,about 4weeks and I’ve read through the service history nothing mentioned about changing oil and filter in the gearbox so I’ve had a look under car and noticed that the bolts around the gearbox sump are ordinary bolts not torx bolts every were else on the car they have used them.. so do you think it’s already been done??? I’m looking at ordering the kit just to be on the safe side. I’m of to Devon tonight so looking forward to the drive down there😁😁😁😁..
Post #519919 28th Jun 2019 11:31am
DrRob
Get it megaflushed to change all the oil out..... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #519933 28th Jun 2019 12:41pm
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
When I asked ZF in Darmstadt (I Live in Germany) for an oil change they suggested to also change some rubber parts in the control unit.
It makes the control valves sit in their original position.
Those rubber caps do flatten over time.
The oil & filter change & and those new rubber bits made my 3.6 TDV8 shift much smoother.
It had 210000km at the time.
Post #520000 29th Jun 2019 6:57am
ur20v
A Trap
Agreed, the rubber ‘stops’ in front of the solenoids make a big difference to shift quality especially the first to second.
Aldo the bridge rubber.
ZF do a full service kit and it’s worth doing on higher mileage cars or any with poor shift quality.
Post #520035 29th Jun 2019 5:16pm
Rambles
Are there any ZF service centres near Brighton?
Post #520113 30th Jun 2019 10:37am
