![]() | Home > Maintenance & Mods (L322) > Calling engineers: how do I avoid drilling my engine block? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
Posted here https://www.fullfatrr.com/forum/post520114.html#520114
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35811 ![]() ![]() |
my only thought is engine heat...screwiing in a pipe would be better job than some kind of adhesive... ... - .- -.
it probably is greg |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
I think when they put the bung in it has a concave shape so then apply some bonding and then hit the centre which expands the plug into position? |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
I like your idea GGDR, it would make the modification a lot easier, but......if it was that simple, wouldn't JLR make that the official modification instead of drilling and all the associated swarf worries?
Well maybe not. If Ford were found to be contractually responsible, then surely the fix is belt and braces, with Ford picking up the bill? (Or their insurers). Making a quick fix not too relevant. Just my theory.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
The simple answer is yes, you can get suitably bonding and sealing agents. Speak to a 3m rep or similar.
Here's the JLR modification fitting
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3866 ![]() ![]() ![]() |
Greg,
