![]() | Home > Technical (L322) > Air con smell |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
Probably needs disinfecting - best take it to an air-con specialist (not a "Quickfords" type outfit.)
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
bomb it......
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 339 ![]() ![]() ![]() |
Halfrauds used to do an "air con bomb" that you set off in the car, started the a/c and it sucked in and it deodorised the system. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7996 ![]() ![]() ![]() |
When you say you have been using the air con a bit lately....... why aren’t you using it all the time? Might be why it stinks....
Jri711 Member Since: 26 Feb 2019 Location: Norfolk Posts: 22 ![]() ![]() ![]() |
Cheers guys, when I say a bit I mean having it blowing flat out, the bomb thing seams the first thing to try (cheap & easy) |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
When was the pollen filter last changed? Could be that. John
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
Asda sell an air con bomb for around the £4 mark....
