![]() | Home > Technical (L322) > Mirror Glass Question |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7996 ![]() ![]() ![]() |
Yours will be heated and chromatic....so about £100 if I remember right. Can get a non chromatic one for about £40 odd, but it will never match your passenger side and won’t dim if a car is behind you.
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 835 ![]() ![]() ![]() |
From memory the dimming ones also have more than two connections on the rear of the mirror.... ______________________________
Jon G Member Since: 02 Dec 2016 Location: Leicester Posts: 120 ![]() ![]() ![]() |
Thanks Guys.
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 713 ![]() ![]() ![]() |
AFAIK, the variations available are :
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Hi
Maybe it’s been replaced before.....with a cheaper one..... see what Dan comes back with.
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
If only two spade connectors in the corner it’s not dimming and also the dimming has a different fitting to the mirror as well and another plug to dim,I’ve just changed mine which was just heated 15 quid off flea bay.
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 ![]() ![]() ![]() |
I appreciate this is an old thread but would anyone know the relevant part numbers for a dimming drivers side door mirror glass for a 2007 Vogue SE?
