Home > Technical (L322) > Todays Suspension Fault Is.....
AJGalaxy2012
Hi Guys,
I've had this fault twice now over the last month or so, any pointers?
RLM-Suspension
C1A13-64 (AF) Pressure does not decrease when venting gallery - Algorithm based failure - signal plausibility failure
( on 02-07-2019 11:13:04 at 219230 km )
Many thanks in advance. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #520320 2nd Jul 2019 11:56am
DrRob
Is it the one where drilling a hole in the brass vent plug solves I wonder? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #520323 2nd Jul 2019 12:11pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Agreed -- simple place to start -- could save a whole heap of head scratching Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #520326 2nd Jul 2019 12:25pm
AJGalaxy2012
Please tell me more BMW i3 Electric Car
Post #520333 2nd Jul 2019 1:02pm
https://www.fullfatrr.com/forum/topic23038.html ... - .- -.
Post #520336 2nd Jul 2019 1:06pm
gavinn
I just took my brass vent plug off and threw it in the boot somewhere, works much better now, the occasional PSHHHHHH noise from the back but i can live with that.
Post #520338 2nd Jul 2019 1:13pm
AJGalaxy2012
Done that now, see if its cured.
I may have fried the compressor driving back from Belfast with a leaking airbag, if thats not cured it I'll get another compressor.
There didnt appear to be a lot of air going in via that filter, is it only an outlet?
Thanks for your help everyone.
AJG BMW i3 Electric Car
Post #520349 2nd Jul 2019 2:19pm
Bushy30
Yes, outlet indeed, hence when blocked, the gallery can't exhaust Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #520354 2nd Jul 2019 2:56pm
DMRR
Not totally true - the compressor can fail in a state where it also cannot vent. Brass exhaust or not. BTDTBTTS. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #520355 2nd Jul 2019 2:59pm
Bushy30
Oh I wasn't suggesting this is the answer, merely that if it is blocked it would be, and probably the easiest thing to try in an attempt to rule it out Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #520359 2nd Jul 2019 3:12pm
AJGalaxy2012
Guys once again, this forum saves ££££'s. Took the filter off, not had a problem since.
Thanks again all you, youre a great team.
Post #520764 5th Jul 2019 5:42pm
Bushy30
Glad it helped Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #520766 5th Jul 2019 6:25pm
AJGalaxy2012
Bang on the money Bushy, thanks.
Post #520781 5th Jul 2019 8:19pm
