Home > Technical (L322) > Suspension height difference
Westminster_Bri
Hi All
Any thoughts on why my rear left corner sits 20mm lower than the right rear? (Front is equal). It remains 20mm different whether in access mode, normal or off-road...
It rises and falls fine... could it be a calibration issue? Or something more serious? If it is calibration, is it an easy fix? What equipment is needed?
I've checked tyre pressures and checked the height on different ground to rule out ground angle etc... (checked on a level car park)
Any thoughts gratefully received...
Brian
2012 Westminster
Post #520340 2nd Jul 2019 1:39pm
you can calibrate it using a GAP iidtool, instructions how to are in their manual.. ... - .- -.
Post #520346 2nd Jul 2019 2:15pm
