![]() | Home > Technical (L322) > Minimum height clearance for underground garages |
Flyingfocrs Member Since: 18 Oct 2016 Location: On the croft with the horses Posts: 93 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic29359.html
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8109 ![]() ![]() ![]() |
Also factor in that the sign will likely be pessimistic and overstate how low it really is, plus it will refer to the lowest point, so with some familiarity you can likely get away with more.
Woofster Member Since: 12 Jul 2018 Location: Toronto Posts: 121 ![]() ![]() |
Ahh, Stan posted a helpful table of dimensional specs in the old post referenced above. Thank you for the link.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3950 ![]() ![]() ![]() |
I know this is a L322 thread BUT is there a similar chart anywhere for a L405. I've just got one and it seems bigger than my old L322 - is this the case? Geoff |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
its not as high geoff.... I'll see if i have any specs on my laptop.. ... - .- -.
That must be why it seems wider, it possibly explains why it’s more economical |
here you go mate,
if it helps theres a owners manual [US version] in the wiki .... ... - .- -.
Amazing Member Since: 17 Jun 2015 Location: China Posts: 61 ![]() |
Always an issue here in China as most parking is underground with most having 1.85m clearance newer buildings are 2.0m which makes people avoid cars over 1.85m because of that(poor new defender). it is better to have and not need then need and not have |
It's interesting because underground parking was never really an issue on my mind until I got my 1st Range Rover. These days, when required, I will drive my smaller daily driver into the downtown core just so I don't have to worry about overhead clearances in underground parking garages! 2010 RR SC
