![]() | Home > Wheels & Tyres > Changing colour of wheels |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
If they’re going to take them of the car, remove the tyres, strip the existing finish (which they should), repaint, mount tyres, balance and refit then that’s probably fair for where you are. You could probably get it done for slightly less if you don’t mind them spraying straight on to the existing finish and risking some paint peeling. |
PS: 20’s work even better! |
Felstmiester Member Since: 06 Apr 2019 Location: Hertfordshire Posts: 262 ![]() ![]() ![]() |
no. Process is remove wheels from car, deflate tyres and break bead on front of tyre, scotch ( key original paint ) spray front of wheel only and lacquer, re inflate, refit wheels. |
I wouldn’t be happy with that!
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 232 ![]() ![]() ![]() |
My life local wheel specialist quoted me £85 a wheel if I supplied them loose wheels.
In reality. Going on prices it would be cheaper to buy another decent set of wheels the same as I’ve got but in black, swap my tyres over and sell my old wheels. The wheels I have can be got in gloss black as well. |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Not that it's relevant but I hate with a passion black wheels and you will absolutely ruin the looks of your motor.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1427 ![]() ![]() ![]() |
Just in case it helps you, stan is selling some black style 502 wheels (see For Sale and Wanted section) and while there seems some prospect of a deal with someone else, if these were still going (£400 for four) they would be almost as cheap as getting your 21s painted and you would have a spare set for winter tyres etc.
