Home > In Car Electronics (L322) > Bizarre amp issue
jameshill
Bizarre amp issue
Hi everyone, hope you're all good.
First time posting, so I apologise if I've missed anything I need to do. Wondering if anyone has heard of or seen this issue before? I've searched many forums, but it doesn't seem this has been covered specifically.
I have a 2003 Range Rover Vogue L322, and recently the radio stopped working. When the car was turned on, 9 beeps sounded that I hadn't heard before. Low and behold, water had got into the left area in the boot where the amp is. I disconnected everything, cleaned and dried it all, still didn't work. Took everything to bits, cleaned all the parts with flux cleaner/remover, put it all back together, still the same beeping and no radio. It seemed like the radio and computer etc were still working, so narrowed the issues down to the amp.
I found a replacement amp on eBay for quite cheap so thought I'd try it out: https://ebay.us/BOTcap.
Didn't work, but the beeps stopped. I noticed when unplugging the 18 pin connector on the amp with the radio still on, there was music for a second!
After swapping around some wires in the 18 pin connector, I managed to get it to work. Sound in all the speakers, bass etc, all back to normal. Still works when turning the radio on and off.
Now, the issue. If you turn the car off and back on, no sound comes from the speakers again (although you can hear speaker 'static' if you turn them up to the full volume). If you unplug the 18 pin connector and put it back in, it works again.
Obviously, I don't want to to that every time I turn the car on, any ideas for a potential fix?
Thanks,
James
Post #521769 15th Jul 2019 11:11am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Hi James,
eBay link doesn't go anywhere of any use!
Now I can't remember what's in that specific connector but the issue sounds like a control line issue, the bit that turns the amp on -- I'd start by looking at I-bus connector very carefully
Might give you a start
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #521786 15th Jul 2019 2:46pm
jameshill
Ah, apologies, fixed the link: https://ebay.us/BOTcap
Interesting, it's an amp from a BMW, do you think it needs recoding to work with the L322? Been reading up on it, although have no idea how to recode it myself.
Just crazy it works if you unplug and plug it back in.
Thanks,
James
Post #521788 15th Jul 2019 3:15pm
Bushy30
OK I thought that was the unit you were referring too.
I'd start looking at decoding I-Bus and seeing if all the kit can see each other, that black unit is the DSP -- and I believe that controls, via I-bus, turning on the amp.
Hope that helps Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #521790 15th Jul 2019 3:22pm
jameshill
Great, thanks, I'll investigate.
Surely it can see it though, if I can edit the DSP settings in the head unit, and can hear speaker 'static' when you turn the volume up?
Thanks,
James
Post #521792 15th Jul 2019 3:41pm
Bushy30
Yes, I agree, but is it then sending the correct signal to the amplifier (silver box) to turn on? !!
I believe it is the DSP that then tells the power amp to switch on you see Smile via the I-Bus Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #521794 15th Jul 2019 4:01pm
jameshill
Ooooh, interesting. Thanks!
From what I can see from the RAVE manual vs the new Philips amp wiring diagrams the wiring is set up correctly for the 18 pin connector. Haven't checked the 15 pin one though, maybe that doesn't align.
I'll have a play tonight.
https://www.bimmerforums.com/forum/showthr...elp-needed
Cheers,
James
Post #521795 15th Jul 2019 4:15pm
jameshill
Not had any luck here. Bought this cable off eBay to see if I could recode the DSP using the details below, but couldn't get it to connect to Navcoder or NCS Expert. Not sure if anyone has ever had any luck connecting to an L322 with either of those? Followed loads of different instructions and just wouldn't connect, even though it would be recognised fine by the BMW INPA application.
https://www.ebay.co.uk/itm/USB-OBD-K-Dcan-...2749.l2649
Quote:
Insert the following parameters
Polling Timeout: inaktiv
Controller: mid_basis
1. Read the AMP module with NCSExpert in Manipulation mode
2. Edit the module settings and find the value : BEDIENELEMENTE
3. Change the value from "bordmonitor" to "mid_basis"
4. Save the new configuration file
5. Run SG_CODIEREN in NCS Expert
Think i'll try buy a replacement amp from the same car instead of a BMW one, surely that will work Neutral
Post #523982 7th Aug 2019 4:27pm
Bushy30
You'll be needing I-Bus I think.........
Look for Resler interface:-
https://shop.ibus-app.de/en/shop/accessori...ncl.-cable
And NavCoder: -
http://www.navcoder.com/ Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #523985 7th Aug 2019 4:35pm
jameshill
Interesting, will take a look!
Cheers,
James
Post #523987 7th Aug 2019 4:41pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
ive currently got the seem beeping noise as you had pal and my head unit is doing the square route of sweet FA , think im going to look at what you did initially and see if I can at least coax some life into it
Post #524296 9th Aug 2019 7:49pm
jameshill
Could I hell get this to work, ended up biting the bullet and shelling out for a replacement amp pulled from a Land Rover instead for about £160. Works a treat.
Post #525536 20th Aug 2019 2:35pm
Bushy30
Thumbs Up Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #525537 20th Aug 2019 2:39pm
