Home > Maintenance & Mods (L322) > Caravan lights
killa
United Kingdom 2010 Range Rover Autobiography TDV8 Bonatti Grey
Can only think that the new socket on friends car was a tighter fit on old plugs
Post #522070 18th Jul 2019 4:16am
AJGalaxy2012
Fair comment BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #522071 18th Jul 2019 5:07am
Balloonengineer
If you suspect the socket pins are not making a good connection, use a flat bladed screwdriver in the split in the pin to make them a LITTLE bit wider to make them tighter in the corresponding brass tube, as after a while they get bent together.
ACF 50 is also very good as it lifts corrosion
Best wishes
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #522074 18th Jul 2019 8:39am
