![]() | Home > Technical (L322) > Air suspension explosion after working on car |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Did you disconnect the battery before removing parts ! When you do that the sensors should be fine when reconnected. Then reconnect the battery last. Just changed my struts last week and the car levelled itself fine.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
Have a read of AJGalaxy's experience:
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 404 ![]() ![]() ![]() |
The airbag might just have got to that time of its life.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
If the shock absorber is OK I would just replace the bag, dead easy, only the one top nut to undo, thge bag just slides on with the new O rings etc (all in the kit). Island 4x4 £150 for the bag. BMW i3 Electric Car
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
Hi Zebedee, Which parts do you mean? Any link? 2010 4.4 TDV8 Vogue SE |
www.ebay.co.uk/itm/RANGE-ROVER-VOGUE-L322-...1438.l2649
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2752 ![]() ![]() |
Note that those struts are not replacements for CVDs such as fitted to the 4.4 TDV8 and some earlier vehicles. |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 757 ![]() ![]() |
Thanks for the suggestions everyone. Ive just finished fitting a new genuine LR airbag (£214 delivered from rimmer bros with a little haggling)
How did you find the process of swapping the bags over? I thought it was a lot easier than expected. BMW i3 Electric Car
Not too bad in all honestly. The hardest part was getting the new airbag seated over the Orange and Black seals/spacers. A bit of lubrication and some twisting pushing got it on in the end.
