![]() | Home > Technical (L322) > constant pulling to left (not tracking related) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35775 ![]() ![]() |
post #2,
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3854 ![]() ![]() ![]() |
I have read a similar post on here, probably on an older L322, but from memory, having changed and checked everything at the front end.... the problem was found at the back end... tie rod bush broken or similar.
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 ![]() ![]() ![]() |
Could be a sticky caliper. I used a laser temperature machine to see which one was sticking. It was just a rear and didn’t pull to one side but I’d imagine a front would do this |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
and you had four wheel tracking/alignment done...?
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
+1 on four wheel tracking - this will identify the problem.
Out of interest do you still have all the old suspension arms? |
