Home > Technical (L322) > Possible turbo popped
Bogi 6357
Cruising about 80mph early this morning and lost all power and coasted to a stop
Didn’t notice any plumes of smoke , I have previously had a whistle but couldn’t identify any split hoses etc or cracks in inlet manifold etc , currently waiting to be recovered to garage. No error codes on dash and will turn over but won’t start
Day 6 of tdv8 ownership
Post #523554 2nd Aug 2019 8:33am
Your car profile would help sir... No one knows which FFRR you own without it Thumbs Up
Post #523555 2nd Aug 2019 8:36am
AJGalaxy2012
That doesn't sound so good, fingers crossed it's something minor. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #523556 2nd Aug 2019 8:36am
Weegie
In your other thread there was a possibility of a cracked inlet manifold. It may be, with a bit of luck, that the inlet manifold has a crack which has opened up giving the symptoms.
Hopefully better than turbo going. John
GAP iiD BT-Sold
Post #523557 2nd Aug 2019 8:45am
OP says tdv8, but it could be a 3.6 or 4.4 Rolling Eyes frustrating trying to help members and not knowing what their question relates to.. ... - .- -.
Post #523558 2nd Aug 2019 8:49am
Bogi 6357
Sorry guys it’s a TDV8 3.6
Post #523561 2nd Aug 2019 9:08am
so please fill in your car profile so that your next question/post will be easier to answer.... ... - .- -.
Post #523562 2nd Aug 2019 9:09am
Rosco
Never seen so many police this time on a Friday morning..... Rolling with laughter
Post #523568 2nd Aug 2019 9:55am
Bogi 6357
Profile updated , car towed to nearest farm and waiting for recovery to garage ,the mechanic who towed had a quick look
Isn’t convinced that it is turbo as it would probably still start and that there would have been lots of smoke etc , possibly runaway engine , but can’t say untill gets in to have a look take pipes of etc , my symptoms where sudden loss of power and coasted to a stop wouldn’t start , no smoke no error messages , previous to that there was a whistle that had developed over 6 days I’ve had vehicle , does a knackered turbo always cause lots of smoke runaway diesel etc , car still turns over but he noted that it seemed to be turning over faster ? Any pointers on what to look for during diagnosis would be very much appreciated is there any symptoms depending on which turbo has failed . Apologies for not filling in profile ,I have updated
Cheers Ian
Post #523574 2nd Aug 2019 10:33am
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
I swear there's something in the air round your neck of the woods. Twice mine has done something similar on the stretch of motorway between the border and Glasgow. Although mine had the full bingo card of errors, HDC failure, suspension lowering etc. But both times in that same place.
Could it have run out of fuel? Or maybe it thinks it has and cuts the engine? Dodgy fuel sender? 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
Post #523580 2nd Aug 2019 11:08am
Mikey
Downpipes off, check the turbos still turn OK
Lower boost hoses off, check for excessive oil
Post #523584 2nd Aug 2019 12:35pm
Bogi 6357
That’s what the mechanic said this morning actually , as I didn’t have any plumes of smoke etc and it wouldn’t start and that it seemed to be turning over quicker than normal , but said he would have to diagnose once it’s recovered properly and not just towed to nearest friendly farm , I can only pray it’s something like that , just a bit worrying as it had developed a whistle
Post #523587 2nd Aug 2019 12:55pm
Bogi 6357
Thanks Mike , and there was me thinking I had nothing better to do than book her in and have a nice drive up-to Dundee to drop of for exhaust manifold 😂 , thanks for your input it really is appreciated
Post #523588 2nd Aug 2019 12:58pm
Bogi 6357
I am going to go with a Gerry can of fuel and see if I have run out of fuel , I’ve read a post on here about running out of fuel
And that the range estimation can’t be trusted , car is reading 50mpg range , no idea on fuel gauges but it thought it was odd when I put £90 pounds in and it didn’t even read half tank ? worth a try before I shell out for recovery , anything I need to look out for when restarting if it is just run out of fuel , any procedure to follow , no errors on dash though , this is probably just wishful thinking and I am prepared for the worst 😂
Post #523596 2nd Aug 2019 2:03pm
j_rov
Sounds like fuel issue to me.
Turbo or inlet would have caused dash to report errors.
Turbo or EGR failure would cause rough running poss smoke __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #523597 2nd Aug 2019 2:18pm
