![]() | Home > Technical (L322) > Fire! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
unfortunately you havnt filled in your car profile but i guess you might have a tdv8 4.4???
rabbit17 Member Since: 22 May 2019 Location: midlands Posts: 11 ![]() ![]() ![]() |
I’ve been meaning to fill in my profile |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7993 ![]() ![]() ![]() |
Could have leaked from the pipes at the back, or the seal under the oil cooler....or like I had, the oil cooler cracked. So they may have swapped it but if they didn’t change pipe seals, could now be leaking from there.
Get it on a ramp and check for oil leaks, especially down the bell housing... 👍 |
