Home > Maintenance & Mods (L322) > DIY aircon top up
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
DIY aircon top up
Well ordered the stuff all arrived this morning
3 cans of gas
Hose and gauge
Stop leak
Well located the lp port top left of engine bay near the windscreen
Checked pressure it was low so I put in a can of gas to build up pressure following the instructions
Next went in the leak seal couldn't find a visible leak so was thinking dry seals then following the instructions added 2 more cans ( only 200 ml can I think ) got the pressure up to about 40 psi and low and behold ice cold air
I will see how this goes for a next weeks and update the post
Not a hard job pretty easy in fact
My reason for the diy fix is I couldn't get booked in for a regas because of my work shift pattern
And if it's this quick and easy about 30 mins it will be part of my yearly service
Thumbs Up henda
Post #523969 7th Aug 2019 1:36pm
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Can you put a link to wear you ordered from please?
Matt If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #523970 7th Aug 2019 1:37pm
Henda
Got the gas from these guys https://www.thompsonsltd.co.uk/motoring-aircon/ I got the 3 can pack its about £40 delivered there on eBay maybe free postage or what ever on that site .Pipe and gauge off fleabay ( cheaper ) don't get the Chinese gas as it's a different fitting
Or just order it all from the guys above I used stp stop leak
Like I said might not last but heyho you never know it's a FF thing Rolling with laughter
Post #523972 7th Aug 2019 2:10pm
Swipe
United Kingdom 2004 Range Rover Autobiography Td6 Java Black
I re-gassed my Td6 in May myself after I changed the air condenser out. Really easy job just keep an eye on the psi. Gas was about £50 from Halfords (was looking for a groupon but none about at the time). If just doing a top up the can should be good for 2 or 3 cars.
Lovely and ice cold think it’s about 2-3C when running! 2004 Autobiography TD6 Java Black
Post #524014 7th Aug 2019 7:39pm
drakes
ATS are only charging £59 for air con recharge around here, don't know about other areas, and if it has a leak and won't take the charge then you don't pay. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #524016 7th Aug 2019 7:44pm
Henda
When I had the disco I used ats, sat for an hour then guy says cant do theres a vacuum problem leak I says don't know says guy sorry, waste of an hour
Just been back out and tried the air con it's cold
Post #524020 7th Aug 2019 7:56pm
£37.99 at ATS at the moment if you use a Groupon Coupon. Thumbs Up
Post #524021 7th Aug 2019 7:57pm
AJGalaxy2012
How did you vacuum out all of the air & moisture? did you change the drier too? BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #524031 7th Aug 2019 8:22pm
DrRob
I found a specialist air con guy to do mine as a preventative maintenance...gas has gone up in price Censored
www.avacs.co.uk in Alton
Top bloke, worth the trip. Open on a Saturday morning too Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #524039 7th Aug 2019 9:03pm
Brian Considine
I'll second the route that Dr Rob took.
My A/C worked when I bought the FF but not as well as it should.
Local specialist (as opposed to a "Quickfords" type outfit charged £60 which included ;
1) Initial diagnostics.
2) Sanitise.
3) Evacuate existing gas.
4) Pressure test (& make sure it holds).
5) Refill exact amount of correct gas.
6) Test run for 15minutes.
Also, the specialists tend to be mobile & come to you. 2003 Range Rover Vogue TD6
Post #524093 8th Aug 2019 11:18am
Wafoo81
United Kingdom 2005 Range Rover Vogue 4.4 V8 Barolo Black
Groupon were doing a deal at £39 with ATS, if it's finished Kwik-fit do it all for £59, same thing pressure test, leak check and refill, saves the guesswork
Post #524095 8th Aug 2019 11:33am
Henda
It's been about 11days since I diy fixed my aircon and so far it is performing great , only needing to go on a low fan setting to keep the car super cool , wife says it's too cold Rolling with laughter
Post #525286 18th Aug 2019 6:36pm
Brian Considine
About the same as a trained air-conditioning engineer charges (one who does not fit tyres).
Good luck with any Quickfords type outfits - past experience means none of my vehicles ever go there - not even for tyres (as it happens one of them jacked a vehicle of mine up using the floor pan !) 2003 Range Rover Vogue TD6
Post #525290 18th Aug 2019 6:54pm
BMG
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
Local car aircon place charges £50 and have knowledge on just about every car. It's so cheap as to be not worth bothering with DIY or untrained Halfords type places with the only ability to top up.
If anyone needs in the north west Kent area, I can recommend Aircon Direct in Ebbsfleet.
Post #525307 18th Aug 2019 9:04pm
AJGalaxy2012
Agricultural engineers (repairs to tractors and combines) do a great job and know their stuff at farmers prices! BMW i3 Electric Car
Post #525328 19th Aug 2019 4:32am
