Home > Technical (L322) > i carsoft BCU readings on 05 L322 td6
deltic
Ireland 2005 Range Rover SE Td6 Bonatti Grey
Hi all, having problems with the passenger door not unlocking with the fob, sometimes the two rear doors wont open every once in 30 goes also the passenger window or mirror wont work from the drivers side but will from the passenger ones and the puddle light dosent work on P/S. I got these readings on the icarsoft i903 from bcm
1. Body control unit unlock short to ground
2. Body control upper tailgate short to battery
3.body control unit superlock relay short to ground
4.Body control unit lock relay short to ground
5. 0081
6. 0080
7. Interior security fuse or cable
8. Drivers door mirror switch inactive
DONT KNOW WHERE TO START,ANY IDEAS THANKS.
Post #524535 12th Aug 2019 1:34pm
Paul thornton
It's probably the BCM failing. Quite a common fault unfortunately
Post #524546 12th Aug 2019 4:40pm
Balloonengineer
I had my BCM repaired by Autoelectron and he is very good, reasonably priced, and a quick turnaround
Best wishes
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #524652 13th Aug 2019 5:29pm
