Home > Maintenance & Mods (L405) > Rear Diff pinion seal
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Just had the car in for annual service and MoT. All good but with minor advisory “to keep an eye on”, which is a weeping rear diff pinion seal. Being a mechanical numpty, can any more enlightened members tell me what this means and how, given its location, I keep an eye on it?
Thanks
Andy
Post #524556 12th Aug 2019 5:45pm
CS
Some more expert person can maybe comment on the implications, but as regards keeping an eye on it, you could put the car on the off road height and slide under it, perhaps wearing a head torch to locate the leak. Having done so it would be a case of watching the ground underneath for any drips of oil in the relevant area (roughly between the rear wheels I would say). If your car is garaged you could put something underneath to show any drip, if you don't (say) have a light painted floor that would show it up anyway,. e.g. a piece of cardboard.
I've seen threads about this problem, so it may be worth a search. Only Range Rovers since 1988
Post #524558 12th Aug 2019 6:38pm
Andy S
Thanks CS, sounds like a good idea re putting it off road height and having a peak. I don’t have a garage, or even off road parking, so the car is never parked in the same place, just wherever I can find a space in my street, so checking for driipped oil on the ground is a bit of a challenge. Will keep an eye out though.
Post #524563 12th Aug 2019 7:26pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
This is a known problem (see my other posts). LR do a repair kit for it and it should be covered under warranty if you have one. Get it repaired asap is my advice.
Post #525048 16th Aug 2019 12:14pm
Andy S
Cheers. The car is LRAU with a 2 year Warranty, so I should be covered. I'm surprised the dealer didn't just fix it in the circs, so I will follow up.
Post #525075 16th Aug 2019 3:56pm
