![]() | Home > Technical (L322) > 4.2 SC slow warm up |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
If its failed partially open eg some debris in it, that would give you slow warm up but normal temperature at other times. BMW i3 Electric Car
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2265 ![]() ![]() ![]() |
Glibbs- two questions - did this fix it?
Glibbs Member Since: 18 Aug 2019 Location: West Somerset Posts: 114 ![]() ![]() ![]() |
I found a rubber gasket which was part of the thermostat itself had somehow become dislodged. I purchased a new thermostat prior to start work so I installed that and all was well apart from the fact that a housing seal was not included with the new thermostat which resulted in a small leak (a cupful a week) until yesterday when I installed a new one. Caution - the lower bolt of the housing is only too easy to drop never to see the light of day again! |
Thanks guessing you didn’t remove the whole housing? Just the thermostat end with three bolts so you can access it? |
Indeed. |
