Home > Technical (L322) > L322
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
L322
Today I take a litle ride for the morning cofee.
On return home, I start the car, the off road light appear on the panel (it happens manny times). Normaly I switch off and then on and the engine starts and the light goes off.
Today after switch of it won't fired anymore.
The lights on the panel are normal, the engine cranks but won't fire.
I tought it could be the key battery because some days ago he warns me about a low key battery. Go there with another key with a good battery but still the same. Won't fire.
What can be?
Cheers
Post #525252 18th Aug 2019 2:35pm
A.Pires
L322
Where the fuel pump fuse
Post #525304 18th Aug 2019 8:41pm
Try the fuel pump relay 5. Swap it for one of the other relays.
Next to rear fuse board.
Also check fuse 15 20A on the rear fuse board
Post #525310 18th Aug 2019 9:15pm
