Home > In Car Electronics (L322) > Is this why my stereo doesnt work ?
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
See picture
Post #525525 20th Aug 2019 1:48pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Your photos are in your gallery............
And I'd say is more than a fair chance that's why it doesn't work ! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #525529 20th Aug 2019 2:03pm
bembo449
Ah right , im on my fone pal and not really got a grip of uploading direct , im trying to see if cleaning it up will help ( doubt it ) the nav now flashes power led where before it was steady red on
Post #525531 20th Aug 2019 2:17pm
Bushy30
Take the lot out -- all units, get lots of contact cleaner and a soft tooth brush, clean everywhere, take the boards out of the boxes, leave to dry in an airing cupboard after using the contact cleaner, reassemble and plug back in, you may just be lucky.
I have to re-manufacture some pin connections on mine, but all worked well after that Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #525532 20th Aug 2019 2:24pm
bembo449
Ok pal , ive thoroughly cleaned it , it was the last unit as id done the others
I hope i am but if not i reckon i will have to go android , cant see me getting a good nav unit cheap ??
Post #525535 20th Aug 2019 2:26pm
Bushy30
You can upgrade the CD nav unit to a BMW DVD unit know as a mark 4 -- up to date discs are available for that -- simple swap just wait for everything to sleep disconnect the CD unit, connect the DVD unit Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #525539 20th Aug 2019 3:00pm
bembo449
Oh right , wheres the best place to find one of them , fleebay ??
Post #525550 20th Aug 2019 4:15pm
Bushy30
Just an example -- nothing to do with the seller: -
https://www.ebay.co.uk/itm/BMW-3-5-7-X5-E3...SwDkBbzOxs Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #525553 20th Aug 2019 4:19pm
bembo449
Cool , least i know what i need , is there any significance in the nav player power light flashing pal ?? You mentioned thing need to go to sleep etc
Post #525563 20th Aug 2019 5:00pm
Bushy30
I think when it's flashing it just means there's something wrong somewhere -- open the boot leave the car for 10 to 15 mins then unplug units, if you don't leave all the units to go to sleep they can screw up when disconnecting Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #525565 20th Aug 2019 5:11pm
BMG has the whole kit and caboodle for sale:
https://www.fullfatrr.com/forum/topic52514.html .
Post #525573 20th Aug 2019 7:26pm
bembo449
ok , before I found the problem the power light was steady , I will do as you say tomorrow and see what occurs ?
cheers
Post #525586 20th Aug 2019 9:28pm
bembo449
quick question guys , ive been offered a MK4 DVD player that doesn't read the disc anymore , im not worried about the NAV part but will it still be good enough to get the stereo working again ???
Post #532109 25th Oct 2019 2:53pm
Bushy30
I think you'd have to ask yourself why it doesn't read discs -- if part of it is failing then all of it might! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #532117 25th Oct 2019 3:44pm
bembo449
yes that's a valid point pal
Post #532122 25th Oct 2019 5:49pm
