Home > In Car Electronics (L322) > Cluster swap?
Danwilderspin
Cluster swap?
I am having problems with my illumination of my cluster and climate module
If I swap my cluster with a used one I know the mileage will be wrong but should it all work so I can quickly see if it works?
If it does I can swap the mileage chips over so it’s correct but don’t want to mess about with that unless it fixes it Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #525689 21st Aug 2019 2:01pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Dan - which one are you talking about? The BMW ones you can definately change and they will work to a point (although the tamper dot will be displayed on the mileage and they are VIN coded (and diesel and petrol clusters are slightly different) but they will work.
Not sure about the Jaguar ones though.
Might just be easier to see if these guys can test and repair your existing one - https://cartronix.co.uk (used them to fix my gauges on the 2004 a while ago) Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #526342 28th Aug 2019 1:22pm
Danwilderspin
Just the jaguar one - the backlights aren’t working so was going to test if it was the cluster before wasting time coding it if it wasn’t... cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #526387 28th Aug 2019 8:24pm
