![]() | Home > Technical (L322) > 2003 L322 continuous beeping |
24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 166 ![]() ![]() ![]() |
Hi all
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
There is a buzzer box on the inside of the panel directly above the pedals (where there is a footwell courtesty light). That is likely the source of the noise - disconnect that and see what happens.
Unnecessary quote removed
To further help eliminate stuff, this morning I have:
I suspect your buzzer box/parking sensor noise is unrelated to your other issues and that will be a broken or damaged sensor or wire in the bumpers.
Thanks Nicksaab.
Following from my previous post, I disconnected the battery and took the ABS connector off - all looks clean.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
The sounder under the driver's footwell is for the parking sensors, this points to an issue with the parking sensors, their wiring, the ECU... .
That's weird then, because I am sure the parking sensors are still working....
yep - just double checked - parking sensors are working fine. 2010 L322 Autobiography Black Edition
The parking sensor beeping mentioned above was playing on my mind (thanks Joe90!)
