Home > Technical (L322) > Not starting
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Not starting
So a few weeks ago had a problem with the car not starting after about 4 hours towing the tin tent stopped for a break, Foot on brake press button no turn over just click? When it did start after a number of times pushing button started every time?
So thought it was the battery? Changed it, Thought it was the starter? changed it, It only seems to happen after 3/4 hours towing the Tin tent when the car is hot?
Has anyone else had this or know about it?
Any points where to go to would help? I did look on my IID tool and only can see a DPF filter near full.
Post #526319 28th Aug 2019 9:12am
DrRob
IID show any other fault codes?
The workshop manual in the Wiki has an error code section (it's long!) Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #526331 28th Aug 2019 11:24am
gj88
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Fuel pump? Should be a 2 minute job to rule out
Post #526332 28th Aug 2019 11:24am
mpirie
If you're just getting a click after replacing both the battery and the starter, then i'd be looking at the heavy duty cable that supplies the starter from the battery.
It's possible that the cable is suffering during hot running and opening up thus stopping sufficient juice reaching the starter.
If it was the fuel pump, it would turn over but not fire up.
Mile
Post #526406 29th Aug 2019 7:09am
Tinman
Hi, mpirie, That sounds more like what I am looking for as I have no problem when cold or short runs, I agree pump would only be if it would not fire but turn over all I get is a click? after it cools down it starts.
Post #526411 29th Aug 2019 7:51am
gj88
When my fuel pump went it didn't try to turn over, as I say, a 2 minute job to check
Post #526413 29th Aug 2019 8:39am
Tinman
How did you check the pump?
Post #526466 29th Aug 2019 5:10pm
Baltic Blue
I remember reading someone had a problem with the cable from the battery to the starter. It is several sections and had a bad connection from the starter relay from memory?
Post #526473 29th Aug 2019 5:47pm
Sandyt
I replaced mine on my 2007 last year bought the whole harness as had a similar issue with my p38 and it was corrosion inside the cable and when hot just not delivering enough - on the p38 bought a premed from auto factors and just put it in as well as original
Post #526475 29th Aug 2019 6:02pm
mpirie
Tinman, have a search for "4.4 tdv8 starter".
There's a thread that Mike (baltic blue) mentioned and there's comment on replacing the starter cable.
Mike
Post #526491 29th Aug 2019 8:22pm
Tinman
Cheers Mike on my way to investigate Thanks for the tip Thumbs Up
Post #526496 29th Aug 2019 9:23pm
mpirie
Here you go: https://www.fullfatrr.com/forum/topic31909...rter+cable
Mike
Post #526520 30th Aug 2019 8:37am
