![]() | Home > Technical (L322) > Cam cover gasket replacement cost? 4.4 V8 |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 826 ![]() ![]() ![]() |
i changed mine
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Did you change them yourself? |
yes RR 2005 4.4 petrol
This is why I think I might be better paying an expert! |
You’ll be lucky to find a garage to just change the gaskets... They are a rubbish design! Most garages want to replace the rocker covers too as they warp with age! Then leak immediately again! This then leads to complaints, hence most wanting to change the lot!!! |
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 ![]() ![]() ![]() |
I did mine and found it a bit fiddly when I tried not to remove the injectors and associated bits. On the other side I did remove them and it made it a lot easier.
