![]() | Home > Technical (L405) > Disable all interior lights? |
pawsinmud Member Since: 26 Mar 2019 Location: Hampshire Posts: 34 ![]() ![]() ![]() |
On most Land Rovers if you press and hold the interior light switch for about 3 seconds, the lights will flash and then they are switched off, You can turn them back on the same way. 2011 TDV8 Vogue SE |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
Wot he said ^^^ Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
yours will be touch sensitive but the disable works the same way as described above.... ... - .- -.
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1279 ![]() ![]() |
Good to know , as on occasions non fare paying freeloaders in the back adjust the airflow and inadvertently touching the lights, which then remain on.... |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1091 ![]() ![]() ![]() |
I think its called stealth mode. My car had been set that way so had to consult the oracles on here to find out how tonswitch back to normal |
