Home > Technical (L322) > Remote locking key sync for Japanese spec 4.2
davidmg
2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Are there any Japanese members that can help me with a 2004 (2006 model year) 4.2 SC built for Japan?
It has the two button key which uses infra red to operate the central locking. No matter what I try I cannot get the keys to sync to work the remote locking.
Do the Japanese market have a different way of syncing the key from the normal UK three button key?
Post #526954 3rd Sep 2019 2:11pm
if any one knows it will be Bushy, give him a shout,
https://www.fullfatrr.com/forum/topic52246.html ... - .- -.
Post #526958 3rd Sep 2019 2:29pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Should be the same for all 2002 to 2009 -- though the units sometimes have a real wobble.
Let me do some digging through my docs and see if I can find anything specific Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #526960 3rd Sep 2019 2:34pm
davidmg
Thank you.
As far as I can test everything seems it all seems to be fine.
So far I have tried an new mirror, different BCM etc. The sensor in the mirror seems to work as the voltage changes when you press a button on the key. The wiring from mirror to BCM seems to fine. So at a loss what to try next Sad
Post #526961 3rd Sep 2019 2:44pm
Bushy30
Hmm, I may be wrong in my early assertion !
Completely different system -- not come across it before, I wonder if IID can test it?
Anyway -- this will throw a small amount of illumination: -
https://www.fullfatrr.com/forum/topic29782.html Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #526964 3rd Sep 2019 3:37pm
spgmcb
This will be the set up on any repatriated l322 re imported from Japan.
Post #527070 4th Sep 2019 6:20pm
davidmg
Well after a tip off from a friend suggesting I search for BMW Japan import and infra locking, I came across this which has one more step than normal and the remote locking is working! So there was no need to spend all the time and money I did Sad
So if anyone need to sync the two button key with infra remote, this is how you do it.
Post #527100 4th Sep 2019 8:39pm
