Home > Technical (L405) > Restricted Performance SDV8 4.4
1959terry
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Had the above warning come up whilst driving at 50 MPH on cruise control. Managed to get where I wanted eventually however on the return trip it happened again. Called the Land Rover assist who arrange for the technician to meet me at my house about 2 hours later.
He opened the bonnet removed the engine cover and removed the MAP sensor. He said it was quite common. he showed me the sensor which had a thick layer of soot on it, about 3mm. He cleaned it with brake and clutch cleaner and replaced it, he put it on the computer and cleared the fault message and all good.
Took about 10 minutes so may get someone out of trouble if they have this issue? 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
2009 Triumph Bonneville, 1959 Triumph Bonneville, 1969 Triumph Bonneville, 1975 T160 Triumph Trident, 2014 Suzuki Gladius, 1990 Harley Davidson Fat Boy.
Post #527084 4th Sep 2019 7:05pm
dolph34
Good to know Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #527088 4th Sep 2019 7:13pm
Baltic Blue
Before cleaning
After cleaning
Mine is a 4.4 tdV8 but L322.
5 minute job to clean it.
I do mine every 2-3 k miles.
Post #527096 4th Sep 2019 8:21pm
nino_nino
I clean mine at every oil change (5K km). Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #527122 5th Sep 2019 8:46am
Baltic Blue
+1 every 6 months, which with my low mileage works fine.
Post #527124 5th Sep 2019 8:49am
carrint71
Where do I find the MAP sensor please?
Post #527934 13th Sep 2019 6:02pm
Baltic Blue
Just pull the engine cover off and...
Post #527935 13th Sep 2019 6:09pm
carrint71
Thank you!!
Post #527946 13th Sep 2019 8:00pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
on this, I'm a little confused, I thought a MAP (some cars used a MAF) sensor was the thing that sits usually just after the air filter on the intake to measure air pressure / flow ??
Indeed there are two (one for each air box) where I would expect them to be on the RR....so what does this measure that gets sooooo sooted up ? - clearly nothing to do with air intake, so I assume some reason the ecu needs to measure recirculation pressure for exhaust/ oil blow by for emissions?
thanks
Post #528529 19th Sep 2019 1:45pm
1959terry
Update
I Got the restricted performance again so called Land Rover assist who said that it may be a turbo actuator issue.
Get this, hire car arrives tomorrow for a maximum of 9 days and my local garage said they will not be able to look at my car until late October????? Has anyone had this and if so what was the outcome? 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
Post #528738 21st Sep 2019 8:35pm
GGDR
Probably not a turbo actuator Terry, could be a loose or split hose.
The error code sounds same as mine, something like 'loss of turbo pressure'
Have a check around your hoses?
. Cheers, Greg
Post #528739 21st Sep 2019 8:44pm
1959terry
It's in the dealers at the moment so will see what they come up with. Said they would get back to me in 48 hours which was up today so I will call tomorrow.
They have however done a free safety check on the car and sent me a video. They are suggesting that I change the front tyres with nearly 4mm of tread on them. Shocked 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
Post #529066 25th Sep 2019 4:26pm
^^ Standard! ^^
Rolling Eyes Rolling Eyes Rolling Eyes Rolling Eyes Rolling Eyes Rolling Eyes
Post #529113 25th Sep 2019 10:01pm
CS
To be fair LR recommend not going below 3mm. Only Range Rovers since 1988
Post #529152 26th Sep 2019 12:21pm
1959terry
Finally got the car back. They replaced the compressor shut off valve and turbo.
Glad that was under warranty 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
Post #530404 9th Oct 2019 4:08pm
