Home > Maintenance & Mods (L322) > 4.4 tdV8, brake pad fitting kit.
Baltic Blue
Please can someone confirm exactly what comes in the front and rear brake pad fitting kit. and do I need to order 2 , ie 1 per side ?
Am I right to think you get....
Fronts.
2 New retaining pins
I pin retaining spring clip.
1 wear sensor
Rears
??? Please tell me.
Wear sensor ?
Post #527207 6th Sep 2019 8:58am
mpirie
Normally, the fitting kits are per axle, so 2 springs, 4 pins, 2 spring retaining pins with screws etc.
They don't normally come with pad wear sensors, at least mine didn't. If you are careful (and assuming they are not damaged) you can reuse the sensors.
Mike
Post #527208 6th Sep 2019 9:16am
Baltic Blue
Thanks Mike, I was unsure, and didn’t want to over order.
Post #527227 6th Sep 2019 11:46am
mpirie
If you plan to reuse the sensors, look out for the small spring-steel clips that hold the sensor to the pad.
They can get stuck on the pad and get thrown out if you miss them.
Mike
Post #527262 6th Sep 2019 7:42pm
