![]() | Home > Technical (L322) > Wtf is going on ( suspension) ? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7996 ![]() ![]() ![]() |
No idea really, but maybe it shoved more air into the rear bags to keep the car level with the engine block in, so when you removed it, the back was pushed higher......but.....the car should deal with the weight being removed, and then drop the air in the rear bags.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817 ![]() ![]() ![]() |
That makes sense pal, guess it hasnt registered the fact the weight has been temoved ? |
Right , plugged in with Delphi and got a canbus fault and front right height sensor / left rear height sensor , i deleted the codes and it seems ok but it wont go to off rd height but i guess the pump is getting warm |
