Home > Technical (L322) > Coolant Change 4.4tdV8
paul70
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
I am wanting to change my coolant before this winter arrives. Is there anything special I need to be aware of. Was just going to drain from radiator hose and refill via reservoir?
The only reason I ask is I used to have an MG which had a special place to bleed from as it got air locked.
Paul.
Post #528187 16th Sep 2019 10:14am
Baltic Blue
PM your email address and I will send you the full draining and re- filling PDF. for the 4.4 tdV8.
Post #528190 16th Sep 2019 10:50am
Baltic Blue
Done Thumbs Up G reg 2.5VM Vogue Portofino red 1991- 1999
Post #528191 16th Sep 2019 11:11am
paul70
Many Thanks
Paul
Post #528192 16th Sep 2019 11:23am
paulparry82
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Barolo Black
Hi Baltic Blue, I'm looking to change my coolant too. Would it be ok to get a copy of that pdf guide please?
Post #545948 4th Mar 2020 10:52am
Baltic Blue
It’s in the Wiki at the top in the workshop Manual.
If you can’t find it PM me your email address and I will send it direct.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #545955 4th Mar 2020 11:50am
