Home > Technical (L322) > Strange DPF problem
Peskyfoxs
United Kingdom 2011 Range Rover Vogue 4.4 V8 Orkney Grey
Strange DPF problem
2011 vogue, keep getting dpf full see handbook, then 5 mins later dpf full visit dealer and limp mode. Car turned off for 1/2 hr and fault gone when restarted. Been to independent several times and no codes other than dpf full. Car then drives fine after 1/2 hr stop .
Been told its my driving thats doing it, do a couple of 2 mile round trips a week then a long drive on weekend using either motorway or a roads
DPF cant be regenerating as drives fine after limp mode so if the car was sooted up from 2 small journeys why is the fault clearing ?
Anyone had anything similar ?
Post #528309 17th Sep 2019 12:20pm
we have some 'dpf' experts here on the forum and i'm sure they'll be along soon to advise....welcome btw.. ... - .- -.
Post #528314 17th Sep 2019 12:54pm
Baltic Blue
Get it on the M62 when it is pretty quiet.
Set the cruise control to 50-55 mph and keep going for a minimum of 30 minutes.
Then it will be fine for a few weeks or 300 miles or so.
Post #528315 17th Sep 2019 1:09pm
Peskyfoxs
It’s come up with dpf on the motorway multiple times including when I have driving manual at 2500 revs. I don’t think it’s clogged as the dpf full came on even after a terraclean.
Post #528317 17th Sep 2019 1:33pm
Baltic Blue
Don’t get the revs up, just steady 50-55 mph in D is the best way to get a good regen.
Post #528318 17th Sep 2019 1:50pm
Peskyfoxs
I have tried it every way to regen, I don't think the dpf is full but something is saying it i, garage did a forced regen yet dpf full days later
Post #528321 17th Sep 2019 2:09pm
Baltic Blue
You need to get an analyser on it and watch what is happening.
I use a GAP iid , like most other owners on here.
In live values you can watch the exhaust temperature sensors and the soot build up in grams as you drive along.
Post #528322 17th Sep 2019 2:24pm
Peskyfoxs
Been done apparently, garage have had it for about 6 weeks of the 4 months I have owned it
Just curious if anyone has had the same fault
Post #528323 17th Sep 2019 2:48pm
DrRob
Needs a proper investigation...might have an boost leak or EGR probe faulty etc etc.
Take it to JAS in York or Green Oval in Leeds. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #528325 17th Sep 2019 3:01pm
Peskyfoxs
Thanks, have spoken to Joe at Jas, currently the independent where I bought it from is trying I fix it, they have checked for leaks. Currently I’m told it’s my fault for only doing 2 short journeys in a week then a long drive which I disagree with
Post #528326 17th Sep 2019 3:06pm
ultron
Germany 2008 Range Rover Vogue TDV8 Java Black
Hi,
here in the german forum we had a similar case,
in the end it had turned out that it was the
"Differential pressure sensor"... this error was not timed, only DPF full ....
Car was a 2012er TDV4.4 MY12
Post #528327 17th Sep 2019 3:51pm
Peskyfoxs
Thank you, I will mention it, I thought I can't be the only person who had this problem
Post #528328 17th Sep 2019 3:55pm
DrRob
Joe is your man...
Bedtime reading
https://www.fullfatrr.com/forum/topic48068.html?highlight=dpf
https://www.fullfatrr.com/forum/topic43597.html?highlight=dpf Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #528333 17th Sep 2019 4:24pm
Peskyfoxs
Thanks I have read pages and pages on dof’s bit none seem to cover the fault in having and the fact I’m told driving 4 x 1 mile journeys will soot up the dpf and make the car go into limp
Post #528382 17th Sep 2019 9:30pm
GGDR
You really need an IID to monitor soot as mentioned.
I do a lot of short journeys: 2 mile commute in London traffic, sits there all day and with a cold engine by evening, I do the return two miles.
I get 160-200 mile range between regenerations.
I monitor it on the odometer for a rough idea and using my IIDTool for more precise readings and it helps me know when I need to get it on an A or M road.
Above 17-18 grams of soot you should take it on a run.
Use cruise control and you can sit on 50mph as Baltic Blue mentioned you don't need revs.
Just a constant speed.
The regeneration should take the soot down to below 5 grams.
Once you have an IID you will be able to see
- actual soot level
- when the regenerations are happening
- if the regens are being completed properly (i.e. lowering the soot to below 5g)
Only then can you understand if you do have an issue or not, despite your advice.
. Cheers, Greg
Post #528388 17th Sep 2019 10:04pm
