![]() | Home > Technical (L322) > Gearbox question (TC) not the usual symptoms I read about |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Oh, and while I think about it, I was changing the oils last weekend, and there seems to be a rubber mount of some sort that the rear diff is attached to (in front of it) and that looks well worn. Could that do it?
Looks like that is called a rear cross member insulator |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Maybe ask Tim at Alltrack in Malvern to take a look ?? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I have actually moved from Worcestershire, I will update my profile!
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
If its a knocking noise on roll off, could be the rear transfer box. Needs examination for poss propshaft alignment fault and prob an oil change. |
Thanks. No knocking at all! I have changed both diff oils and transfer case. |
transfer Bearing? or the flanges deteriorating? Dunno otherwise. Sorry.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
You mention plugs and PCV hoses not being in the best condition.... get these replaced before delving too deep elsewhere as you could be running lean and have misfires which might manifest at that rpm range.
