Home > Technical (L322) > Part Identification Help Please. |
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 |
Its the Variable Valve Timing Solenoid seal , to replace the seal its cam cover off as getting it from the top is fraught with damaging issues |
19th Sep 2019 2:31pm |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 252 |
Thanks gavinn. Much appreciated. |
19th Sep 2019 2:42pm |
Just a quick update: I have been told (by the local Indie) that LR do not sell the Valve Timing Solenoid seal separately and so will necessitate purchasing a whole new cam cover (Or something expensive like that) if I want it fixed.
14th Nov 2019 10:27pm |
Land Rover don't do them separate , but Jaguar do , and as its exactly the same engine and fit then you just use a Jag part number , the one you need is AJ82856
15th Nov 2019 12:17pm |
Very helpful indeed! Many thanks Gavinn. |
15th Nov 2019 12:49pm |
