![]() | Home > Technical (L322) > Fuel Burning Heater - Fuses |
| J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541
Hi, have you looked on the inside of fuse cover there's a list there on mine |
| Markbhai Member Since: 05 Jul 2015 Location: bradford Posts: 20
HI
Check fuse 19 |
| JST Member Since: 12 Dec 2013 Location: Somerset Posts: 503
just digging up an old thread. have a 12plate L322.
have also read this, https://www.fullfatrr.com/forum/topic46437.html but i t seems inconclusive for the L322 with various different methods discussed/shown. Cheers
| AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464
I just disconnected the receiver in the offside boot panel, waited 10 seconds, reconnected, press the off button AFTER 2 seconds but before 6 seconds, hold the button for at least 1 second, worked 1st time. BMW i3 Electric Car
Sorted now, thank you. ONly slight difference was the remote unit for the Webasto on my 12plate is right next to the fuse box, not behind it. Cheers
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
My remote just flashes red for a few seconds then stops. What is the definitive way to pair it to work properly on MY2011.
Ignore me. Found in wiki |
What does the receiver look like and which wire did you unplug? 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
The info is in the WM in the Wiki.
Yep! Know about fuse 16 but someone mentioned unplugging the receiver which I assume is a wire feed into a unit... |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
It is the power feed to the receiver. Just unplugs and is pretty obvious when you look at it. Certainly in the earlier models it is just a little awkward to get to as it is tucked in behind some other bits.. John
OK, thanks. New fob battery to be fitted first then will try again to pair it.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
