![]() | Home > In Car Electronics (L322) > M O S T problems Battery related? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35779 ![]() ![]() |
when you re-fitted the battery did you turn the steering wheel fully left and then right.. ... - .- -.
Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233 ![]() ![]() |
Stan. That's a big NO. Could this really affect the vehicles MOST system? Will try later. Thanks. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
ahem...
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
A trick that I have found is with a set of jumper cables connected to the terminals of the car before you disconnect the battery
Stan. Tried the lock to lock yesterday. No change with any of the functions. I am convinced it is a corruption of the files. Looking at having the system flashed. |
lock to lock 'after' a battery disconnection? ... - .- -.
Indeed it was. |
