Home > Technical (L322) > Difficult Morning Starting M62
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
HI,
Has anyone experienced problems with the BMW M62 4.4 engine poor starting and found out what the problem is?
My car starts fine, but for the first few seconds in the morning struggles to accelerate. I can move off, but there is no power, the car doesn't want to accelerate and there are some (concerning for the catalytic converters) pops, etc. The more I put the foot down on the accelerator, the worse it seems. It started about a week ago, and seems to be getting worse.
After 30 seconds or so, it all seems to clear, the car accelerates as normal, and the car is fine for the rest of the day.
I run on LPG, but all this is when the car is running on petrol and before it is warm and has had a chance to switch over to LPG.
I'd really appreciate someone letting me know who has had this problem before and found out what the issue is.
Many thanks Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #528693 21st Sep 2019 9:05am
cass
I would rule out the LPG before looking at anything else.
Physically isolate the liquid supply either at a valve or unplug the solenoids then run on LPG until it stalls. Run on petrol and see if it solves your problem.
I had a similar problem on a Jeep which was an LPG injector leaking. Trying the above costs nowt and rules out a lot of possible causes.
Post #528706 21st Sep 2019 12:11pm
Dolphinboy
Dirty MAF/faulty primary fuel pump/idle rev level set too low?
Post #528737 21st Sep 2019 7:48pm
Zebedee
Update:
Yesterday, the problem got worse. I started the car and it ran fine for about 2 minutes then suddenly cut out and would not start again.
Today, I've started working through the options and one of the first things to try was the fuel pressure Schrader valve - and almost no pressure at all.
Fuel pump out and tested and it is not working at all.
I think what has been happening is the fuel pump has been on its way out and finally gave up the ghost yesterday. I still can't work out why the symptoms where poor acceleration to start with then fine for the rest of the day. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #528774 22nd Sep 2019 5:44pm
Gsxr1250dave
The rest of the day its warm thus running on lpg so doesn't use the fuel pump
Post #528808 22nd Sep 2019 11:28pm
