![]() | Home > Maintenance & Mods (L322) > Anyone have ever done a commercial conversion on a L322 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Do it. Job done. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
They get converted in Eire a lot as the RFL is a tenth of a car... Don't know if that will help you find info? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
You can also get those tight fitting full black out window inserts.
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
Just factor in any insurance issues - some companies are not too keen on commercial conversions. (As I found out a couple of years ago). 2003 Range Rover Vogue TD6 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3880 ![]() ![]() ![]() |
I am no expert, but I think you have to remove the rear seat belts and blank off the fixing points.
