Home > Technical (L322) > Coding ABS module
tveitan
Norway 2002 Range Rover HSE Td6 Oslo Blue
Sounds strange.. Are you able to read the coding file using the command codeiren_lesen? 2002 Range Rover Td6
Post #530064 4th Oct 2019 8:11pm
Loyola1988
France 2003 Range Rover Vogue 4.4 V8 Giverny Green
hello can you sen the L30 file? Where can i download it?
THANX
Post #531395 19th Oct 2019 8:38am
Loyola1988
found it thanx
Post #531400 19th Oct 2019 9:07am
Rewmer
Well after repeated attempts, I gave up and took it to a local specialist. After £48 later she is all good again. No7 - 2003 V8 Vogue
Post #532315 27th Oct 2019 5:13pm
tveitan
It was unfortunate that my solution didn't work for you. At least the lights in the dash is gone, which is always a pleasure Thumbs Up 2002 Range Rover Td6
Post #532385 28th Oct 2019 6:11am
Loyola1988
HELLO
Are you able to find an argument for a l322 2003 v8 4.4 , when i try yours no answer !
thanx a lot
Post #533431 7th Nov 2019 3:21pm
Sx200
Australia 2004 Range Rover HSE Td6 Epsom Green
Post #558315 20th Jun 2020 1:46am
tveitan
Hi. Pm me your email and i"ll send you the file 2002 Range Rover Td6
Post #558982 25th Jun 2020 1:03pm
Sx200
Thanks I managed to find the file, can't get tool32 to work though!!!
Post #560774 9th Jul 2020 10:14am
