![]() | Home > Maintenance & Mods (L322) > .Not wheel bearing. Tire noise. |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
I was sure I had a post about this pseudo wheel bearing noise but can't find it. So an update to those that gave input. I had a front wheel noise that sounded like a possible wheel bearing with that wa wa wa sound that increased and decreased with speed and so some extent seems to increase with right turns. This appeared to be coming from the front left tire. BMW/Land rover certified mechanic checked it and couldn't be certain where it was coming from. Wasn't convinced it was WB.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35811 ![]() ![]() |
40 psi is to much...what size tyres are you running?..if standard size ,i would have 33/36 psi for normal running.. ... - .- -.
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
Pirelli scorpions 235/65 19s. The slightly taller tire also help with cutting through snow and puts the speedometer spot on to my GPS speed. Set of 4. The 2 rears started the slight feathering originally. When I had them rotated is when I first noticed the pseudo wheel bearing noise. Didn't make the connection at first. Yes. I run them with higher pressure. That how I can get 20 mpg (us) highway. Theoretically one would think the centers would wear faster or different with higher pressure. Keep in mind the feathering only showed up on tires on the rear. Now that they have been rotated a couple time in less than 8k miles three of the 4 have at least some slight feathering. It is the out of round sound that has me curious. Perhaps I'll try running them at normal pressure for 10k miles and see what happens. No doubt they do run more comfortable with lower pressure. |
aids22 Member Since: 10 Jun 2019 Location: Warrington Posts: 28 ![]() ![]() ![]() |
I think you have just got a bad batch of tyres.
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
When I phoned the vendor about the L322 I bought back in May he told me that the R/H/F wheel bearing was starting to make a little noise. This did start to get more noticeable after a while.
