Home > Maintenance & Mods (L322) > Changing trim
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Changing trim
Hi, All as you can see the trim was looking a bit naff so ordered a new one from Dan Duckworths as you can see not as easy as I first thought getting it off was the easy part but getting the old glue from the car took about 45min, after picking off the heavy stuff I then used acetone ( nail varnish remover ) works great with other silicone products, ,sticking the new one just needed removing the backing tape and sticking it on.
Post #529291 27th Sep 2019 2:17pm
Fox889
I have the same problem & was thinking carefully of spraying it as there's no damage just discolouration.
Can I ask how much the replacement was? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #529303 27th Sep 2019 5:15pm
Tinman
Hi, Price from Duckworths £58
Post #529317 27th Sep 2019 8:04pm
Range Rover L322
Spray / soak the sticky tape in WD40. Leave it for 20 mins. Spray again. Leave for another 20 mins.
It then comes straight off.
Post #529426 28th Sep 2019 7:09pm
Tinman
Thanks for the tip Thumbs Up
Post #529427 28th Sep 2019 7:25pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
absolutely grotesque for a strip of coloured plastic .
Post #529445 28th Sep 2019 11:36pm
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
Got mine off ebay 12mths ago, real stainless, steel, not plastic junk and only about £20.00,still pristine too. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #529482 29th Sep 2019 3:14pm
nino_nino
can you post link? 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #529489 29th Sep 2019 4:28pm
nino_nino
found it.
https://www.ebay.ie/itm/Range-Rover-L322-C...SwEaBaIIVo 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #529541 30th Sep 2019 8:12am
