Home > Technical (L322) > Water leak through boot hinges into electrics.... Woes
dazza1983
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
Morning guys.
Out of the blue jumped I’m my car this morning and as soon as I pulled away the rear d pillar speakers in the boot started making horrible noises.
Crackling. High pitched ringing just horrible.
Got half way to work and pulled over checked the rear boot compartment on the passenger side and saw this?
I’m guessing water has gotten in?
The noise from the speakers was even continuing when I turned the car off.
Question is what do I do now?
How do I find the leak
How do I stop it. ?
Had the car since feb and it hasn’t leaked yet could it just start out of the blue?
Just to add a additional note incase anyone brain storms like I said hasn’t leaked since I’ve owned it and this weekend it was in for 2 stage paint correction and ceramic coating. Not sure why / how that would affect it but weird it’s started 2 days after? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #529651 1st Oct 2019 8:08am
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
I wonder why this isnt cured since 2002????
They say it leaks from left corner of the trunk.
Take good contact cleaner and try to clean connectors.
If amplifier or subwoofer electronics got wet they need to be dried and cleaned too. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #529652 1st Oct 2019 8:32am
dazza1983
I don’t know which connectors to dry bud?
I’ve also read a little about the boot seal? Is this just the big main rubber seal you see soon as the boots open? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #529653 1st Oct 2019 8:34am
Sunroof drains
Tailgate Seal (inc stuff and muck around the seal)
Rear Side Window seals top,side,bottom
Could be that your detailer was over zealous with the pressure washer on the decontamination clean and forced water in, where under normal use this wouldn't happen, and it took a day or two to trickle down .
Post #529655 1st Oct 2019 9:00am
dazza1983
Thanks for the reply guys.
Ive taken it straight over to my local dealer. I’ll keep you all updated.
I didn’t know where else to take it locally and I didn’t want to chance anything electrical popping especially with the weather at the moment thought it’s best to get fixed ASAP. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #529663 1st Oct 2019 10:04am
dazza1983
I just had a thought. Back in the summer I removed the horrid roof bars that were on there and replaced the gutter mouldings / trims ? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #529665 1st Oct 2019 10:21am
umitbat
[quote="dazza1983"]I don’t know which connectors to dry bud?
All the connectors of amplifier and speaker and other components you have in there.
You have to remove some trims but easy. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #529689 1st Oct 2019 1:45pm
dazza1983
just thinking out loud, but the rear speaker making these horrid noises will be connected to the water right?
Wont be a separate issue? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #529739 1st Oct 2019 7:43pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
The speakers making noises will most likely be damp in the amp or connector and nothing to do with the speakers themselves.
The official 'fix' for leaks in that area was to fit a plastic water shed over the top of the electronics...in other words to not fix it and just redirect the water, nice!
Post #529746 1st Oct 2019 8:29pm
dazza1983
Yeah I already have this sheet lol. So not sure if it’s coming in from somewhere else or if the sheets failed or what.
I kindly said to the guy at the dealers I really want this leak fixed and not just a work around. Fingers crossed.
I wonder would my 2011 have come fitted with this sheet from factory? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #529749 1st Oct 2019 8:36pm
dazza1983
A little update for anyone whos interested however its not a good update:
Car was booked in for diagnosis of leak at the main dealer, my thinking behind this was they will no what they are doing to a decent standard, now i feel like a idiot..
Over the phone when booking it in. Myself and the guy on the phone had a in depth chat and settled on car was booked in for 1 hours worth of water leak diagnosis, if a good diagnosis couldn't be reached within that time then they would call me to authorize more time / money to spent on diagnosis...
So i patiently waited and then out of the blue i received a txt message with a link to this video which is laughable...
https://video.citnow.com/vxpQsZ1_0kY
So after i watched the video and half of me laughed hard whilst half of me got very angry... I calmly called the service department and said.... Im not being rude but please tell me where my 1 hours worth of labour has gone because from what i can see the tech has removed the spare wheel, removed the side cover for the electronics and poked his head in,.... Oh and i am not paying for anyone to tell me how much Tyre and brake pad life i have left... Oh and please tell me how you expect to find let alone fix a leak when you haven't even got the car wet.
The guy i spoke to was very helpfull and told me he would investigate, after 15 mins he called me back and agreed the tech had not done enough work to warrant 1 hours labour and that he was infact jaguar trained and not specifically land rover trained and in fact wasnt really too clued up on range rovers let alone l322;s so now apparently the dealers best tech will work on my car once he has finished rebuilding the head of a defender...
I dont know weather to laugh or cry Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #529843 2nd Oct 2019 5:22pm
DrRob
Does not suprise me one bit. Useless Censored !
I bet you and a mate with a hose pipe could find it in 5 mins flat Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #529896 2nd Oct 2019 10:07pm
dazza1983
It might yet come to that DrRob.
Would anyone have any insight to as weather the amp which we believe is the cause of the crackle and high pitch noise will be ok when it dries?
I’m guessing it’s only the connections which are wet causing the horrid noise through the speakers. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #529898 2nd Oct 2019 10:18pm
dazza1983
Update for anyone. Leak has been found.
https://video.citnow.com/vx6Yx9MQqrs Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #529958 3rd Oct 2019 4:57pm
Spud
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Will be interesting to hear how they fix the leak. Keep us posted please and good luck. 2006 4.2 SC
Post #529965 3rd Oct 2019 7:04pm
