Home > Technical (L322) > Bulb for rear
SinbadRose
Bulb for rear
Hi all,
Just found that the side red bar on the rear light cluster of the car is not lighting up, anyone know what the bulb is before I take it out?
its a 2011 model
cant even remember if its a sealed unit
Post #529764 1st Oct 2019 10:10pm
rjff
I "think" it is a reflector, not a lamp, although there appears to be a hole half way down which may accomodate a bulb, perhaps in overseas markets. According to the Owner's Manual the rear light fitting is all LED, so I understand it's only replaceable as a complete unit. Sad ££££££
The WM and OM are in the Wiki. Cheers
Richard
Gap IIDBT
Post #529890 2nd Oct 2019 9:34pm
as above, the hole for the bulb would be for the US market.
In the UK we dont have side lighting. If you have one lighting up the other side that is the one which is incorrect. It may be that that lamp has been replaced with a non UK spec model Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #529903 2nd Oct 2019 10:33pm
SinbadRose
Yeap, I have one that lights up, one that doesn't. Never noticed it before. I can see the hole on the one that doesn't light up, but if that is how it should be, I now need to find a way of turning the other off Sad Quite like it with the light
Post #529957 3rd Oct 2019 4:42pm
rjff
I think I quite like it with the lamp too, but it's another excuse for a tug if you see my meaning. Sad
Probably best to remove the lit unit complete and see if you can remove the lamp without triggering a fault light. Cheers
Richard
Gap IIDBT
Post #529981 3rd Oct 2019 9:39pm
