|  | Home > Technical (L322) > Westfalia tow bar for L322 - model year differences |
| Andrewmoss Member Since: 05 Sep 2019 Location: Rutland Posts: 4    |
 I’m trying to source one of these second hand but I’m confused if all model years are same or not, before I buy one that doesn’t fit!
|  30th Sep 2019 7:19pm |
| matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 112      | Not sure about the actual main carrier but wiring is different , late ones are dead easy , 1 plug to connect behind the spare wheel and away you go . | ||
|  1st Oct 2019 8:06pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Bit different on an 07, you need a fag packet module which goes in the drivers side rear cubby. all pretty plug and play. The later cars are even easier as said There is nothing that can't be fixed with a hammer😜😜
|  1st Oct 2019 8:23pm |
| Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102      | Have sent you a PM about one for sale Current: 2011 FFRR Vogue SE 4.4 TDV8
|  1st Oct 2019 8:27pm |
| kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386      | I thought it was only the 4.4 TDV8s that were different? Or are they the same as the 3.6 TDV8s (and different to the original ones)?
|  2nd Oct 2019 8:42am |
| Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102      | The 4.4 TDV8 is different, can't comment on the 3.6 -- I had the older version on my 4.4 TDV8, and just used the hangers from the strengtheners -- that's what I have for sale, so would fit both  | ||
|  2nd Oct 2019 4:36pm |
| Posting Rules
