Home > Maintenance & Mods (L322) > Swollen wheel nuts
Rambles
Swollen wheel nuts
Was swapping out some old swollen nuts for new
22mm wouldn’t fit on some. 23mm was too loose.
Found 7/8th worked a treat.
Then in went the new.
No copper slip. Workshop manual says not to.
But some mechanics I am told think it is a good idea.
Anyone put copper slip on wheel nuts?
If you have a decent torque wrench, does it matter?
Post #530208 6th Oct 2019 11:17pm
Range Rover L322
I've done the same recently and I read a ton about the grease / no grease arguments.
The majority say no grease. Just torque them up to 140NM dry.
The reasoning is mostly because with grease = over-torquing and stretching the bolts as well as the possibility they come undone.... all sounds fairly unlikely, but like I say most people say no grease.
Also with new nuts you want to check and re-torque them after 30 miles.
Post #530209 6th Oct 2019 11:39pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
After seeing a very experienced lorry mechanic do this many years ago, I have always put copper grease on wheel nut/bolt threads and I have never had a problem. I would rather have them greased and the wheels tightened up well, than have rusty threads that don't torque the wheels up properly.
I also put a light smear on the mounting face of the wheels, as this prevents them corroding to the hubs.
Post #530211 7th Oct 2019 12:12am
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
The copper serves no purpose in lubricating wheel nuts. It's supposed to be used in applications that burn off the "wet" part of the formula, leaving a smooth copper glide surface. The use of copper grease as an assembly paste is a trend, that the manufacturers of such have used for what it's worth.
Copper between aluminium and steel can increase galvanic corrosion.
If you insist on greasing the bolts/studs, use regular grease, or even better, just a drop of oil on the threads. There are also mounting pastes that does not include active metals. 2007 L322 3.6 TDV8 Stornoway
Post #530217 7th Oct 2019 6:31am
I've put copper grease on wheel studs / bolts for over 50years, never use a torque wrench, just tighten them by feel.
Never stretched a stud / bolt or had a wheel come loose in all that time.
Can get my wheels off when I require to do so with ease.
You try getting RangeRover dry wheel nuts off that have been on for a couple of years at the roadside.
Despite the doom mongers I shall continue to apply copper grease as required.
I also strongly recommended that that the hub spigot is given a liberal coating of copper grease before any wheel is fitted to avoid the wheel corroding itself in place. If a wheel does you will need a really big hammer to get it off. Thumbs Up
Post #530218 7th Oct 2019 7:21am
S.Hafsmo
I'm not saying the car's going to melt because you're using copper based anti seize, just that it doesn't serve much purpose as opposed to regular grease. I use it myself when options are not available.
I see there are people selling stainless bolts for the L322, anyone's got long term experience with using these? 2007 L322 3.6 TDV8 Stornoway
Post #530223 7th Oct 2019 7:59am
Baltic Blue
I bought a set of solid nuts off EBay . They are not stainless, but got a galvanised finish which has dulled, but they are still as good as new after 4 years.
I have looked several times to post a link , but can’t find them now.
Post #530226 7th Oct 2019 9:18am
S.Hafsmo
Would you mind taking a photo of how they look now, after 4 years? 2007 L322 3.6 TDV8 Stornoway
Post #530227 7th Oct 2019 9:22am
Baltic Blue
No problem, except I am away on holiday for next 2 weeks, so when I return.
Post #530230 7th Oct 2019 11:10am
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Galvanic corrosion innit ?
I always slap copper grease on the wheel nut thread and on the back on the wheels touching the hub. I have noticed when its been in for a service my Indy does the same too. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #530233 7th Oct 2019 11:26am
Baltic Blue
I’ve been doing it for 50 years because my dad told me to do it Rolling with laughter never had a problem.
Post #530235 7th Oct 2019 11:33am
dazza1983
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
I researched this a few years back when I had a e46 M3.
I found out that there is a difference between what is known as a dry torque setting and a wet torque setting.
Car wheel nut torque settings are specified in dry torque settings.
If you put copper slip on then you are then creating a wet torque setting.
If your wheel nuts are correctly torqued without any copper slip then there is no reason you need any copper slip.
Putting slip on the huns is however a good idea. Wheels sticking to it corroding to the hub is a nightmare when trying to remove them. Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #530273 7th Oct 2019 8:21pm
GDM
I quite agree on all of that but I do use a torque wrench.
Regarding the wheels sticking to the hub, when I first had my BMW 5 Series it went in for new rear tyres. I had not needed to remove the rear wheels at this time and the tyre fitters had a hell of a job getting one of the wheels off because it had corroded to the hub. I have used copper grease since and never had an issue getting the wheels off. Glad I didn't get a puncture before I had the tyres done!
Post #530283 7th Oct 2019 10:44pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
It's best to use copper grease on unlike metal surfaces. If the wheels have never been off or put back on without copper grease then loosen the wheel nuts and drive the car a few feet and that'll loosen the wheel. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #530292 8th Oct 2019 8:18am
Impact wrenches are the enemy of RR nuts - they cause the caps to become dislodged from the nut underneath & the swelling starts from there.
Copper grease on the back of the wheels but not the nuts for me.
All my wheels come off every 6 months anyway as I run summer & winter tyres - so nothing gets a change to corrode into place too much.
Post #530299 8th Oct 2019 9:57am
