![]() | Home > Technical (L322) > 4.4 TDV8 rattles & ticks (WAS: gearbox issues ?) |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
when was the last time you changed oil in TB/ transfer box/ ? 2012 TDV8 Black Edition
cozzy Member Since: 15 Jan 2019 Location: Norfolk Posts: 76 ![]() ![]() ![]() |
I had a very similar thing with my 4.4 Tdv8 ........it drove me nuts . It was always most noticeable in the first couple of gears , cruising , silent !!
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447 ![]() ![]() ![]() |
Hi,
I got chance to get under the car this morning.
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 434 ![]() ![]() ![]() |
I’ve got this issue on mine too. Drivers side exhaust heat shield rattle. I’ve not done anything about it yet and it stops it’s infernal racket once it’s warmed up. Until warm it sounds dreadful. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2742 ![]() ![]() |
Sounds like the same cause as my recently-cured rattle that vibrated at around 2000 rpm. Some judicious reshaping did the trick. |
Thanks guys.
Thanks John W...on the ‘to do’ list. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
kevy88 Member Since: 06 Oct 2024 Location: Wales Posts: 2 ![]() ![]() ![]() |
I always fear the worst. I had that faint rattle also and convinced myself it must be the gearbox (which does leak a little) as in worst case scenario etc. Of course now I look, it's the heatshield alright. Easy fix with some steel cable ties. I'm at least 150 miles away from any of the good transmission specialists anyway |
