Home > Maintenance & Mods (L405) > Affordable lift links in the UK |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 |
Well, johnson rods are grossly over priced, so I bought a set of these
12th Oct 2019 9:20am |
jumpin mouse Member Since: 28 Feb 2016 Location: North West Posts: 222 |
Allow fitment of 33" wheels
12th Oct 2019 9:36am |
rn322 Member Since: 16 Dec 2021 Location: South Carolina Posts: 2 |
If the Johnson rods "trick" the suspension by changing the sensor readings, has anyone simply realigned using the IID tool and the target heights + 40mm? e.g. 533mm instead of 493mm for the fronts and 523mm instead of 483mm for the rear.
29th Dec 2021 3:26pm |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
I was going to say, if you have a IID tool then you can reprogramme the suspension to your desired heights without the need for the rods! Bish.
29th Dec 2021 6:00pm |
